Hi. I have been capturing 4 a while and havn't had a big problem with droppage. Usually about 1 per minute. Anyway, I have the ATI AIW VE card and I just started using the sourceforge drivers so I could capture at a higher resolution. The first 2 I did w/ the new drivers did ok. Well, I just tried one and it dropped 45 frames in like 10 seconds! I used the PICvideo JPEG compressor set on 18, no audio compression, 44/16/stereo, at 480x480. Same settings as always except for the video (the movie is 2 1/2 hours long, I usually set at 19.) Anyway, I don't know what to do about it. Any suggestions?
make sure you don't have any unecessary background appz runnig. other than that, i'm at a loss
Have you added any new software lately, or changed any settings, whatsoever on your computer? Try changing the compression setting back to 19 and see if the number of dropped frames decreases. There is a pretty good guide here: http://www.vcdhelp.com/forum/userguides/81808.php on tuning a system for ATI captures.
One a minute? That is a lot in my humble opinion. The movie? VHS? I have issues with some VHS tapes too. I ALWAYS drop many more frames from VHS than from my sat tv box. I've come to the realization that it is normal for VHS to drop more frames..... Look up "time base corrector" here if you are capturing VHS tapes. Maybe that can help....Originally Posted by dridge
when i capture in divx i dont loose much frame ... but i still need to try 480x480
US mega millions - you in?
By yoda313 in forum Off topicReplies: 2Last Post: 1st Apr 2012, 08:40 -
Does K-Lite mega Pack support Nero 7?
By Djard in forum Software PlayingReplies: 37Last Post: 20th Sep 2010, 07:10 -
k-lite mega pack codecs 6.30 problems...
By sgbd in forum Software PlayingReplies: 10Last Post: 2nd Sep 2010, 04:46 -
streaming with media player classic + Mega K-Lite Pack problem for AVI
By set69 in forum Software PlayingReplies: 5Last Post: 11th Feb 2009, 20:02 -
DVD Mega Changers - Shuffle Feature
By kaythan in forum DVD & Blu-ray PlayersReplies: 1Last Post: 16th Jan 2008, 18:00
