I wonder, if I try to convert a Divxencoded movie, thats coded with divx3, And I only have the Divx5codec installed, will I benefit from installing the divx3-codec?
I ask this because it takes like 10 Hours to convert a 2hour movie, no matter what converter I use. And tmpgenc doesnt even work, it stops after 10 minutes with a decimal-yadayada error.
No difference whether I try to convert to VCD,SVCD or DVD. Its the same amount of time...
Is it supposed to be like this?
Converting to mpeg does take time. The divx 5 codec works good at decoding it, it is not the speed issue here. One of the only ways to encode faster is a faster cpu. Or you can always play it from an s-video output... Anyways. Good luck... and good patience (har har)
Multiple Divx codecs?
By Huh...What? in forum Video ConversionReplies: 15Last Post: 16th Dec 2009, 09:44 -
divx codecs for Philips DVP5160/12
By petarone in forum DVD & Blu-ray PlayersReplies: 3Last Post: 3rd Jun 2009, 22:04 -
Xvid and Divx Codecs
By Jomapil in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2009, 11:42 -
Divx player - integrated codecs and no installer
By Roccos in forum Software PlayingReplies: 1Last Post: 22nd Oct 2007, 11:49 -
Same Codecs but cant be played on the same divx player
By weeleong87 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 12th Jul 2007, 14:06
