  1. Hi.
    i jus bought a DVD Player for my PC so i could "copy" DVD to VCD, but failing that, i then bough a DVD-R/W (Pioneer DVR-A04).
    the only thing i didnt realise was the size of DVD's (lol)
    so, what i am tryinf todo now is, copy the DVD to my hard-drive so that i can maybe fiddle with it & then remove some of the "junk" that DVD's have then burn the image to DVD-R media !?
    is there a way i can do this?.. and it dosent have to be quick, jus stable!
    i have got: VCDEasy, InstantCD/DVD, SmartRipper, FlaskMPEG, XMPEG4.5.
    if you could help? i would be greatful..
  2. Look this way <-------------------
    http://www.vcdhelp.com/dvdripping
  3. thanks - .. anyway i managed to use SmartRipper now jus gonna read the above link..
  4. ok.. i have been following this guide (http://www.vcdhelp.com/sefy/?id=ClassicalGuide.html) very carefully but i get the followin problem;
    TMPGEnc
    The File "G:\DVDs\Fast_&_The_Furious\video_ts\Fast_&_The_Fu rious.d2v" can not open, or is no supported
    am i doing something wrong?..
