Results 1 to 10 of 10
  1. Are there any programs to convert mpeg 1 to mpeg 2?
  2. Member Treebeard's Avatar
    Aug 2002
    Lots of them but the results may not look good. Are you trying to play an SVCD and your player only plays VCD's? if so try the header trick.
    http://www.geocities.com/newestmoviesencode/dvdvcd
    okay im an idiot that is for mpeg2 to mpeg1 duh!!
    you can use tmpgenc to go from mpeg1 to mpeg2 but it will stretch the imperfections in the picture and the results may look worse than the mpeg1.
    7th layer of hell
    no your and idiot b/c this is a MACINTOSH forum...
    tripps-
    why would you want to convert from mpeg-1 to mpeg-2? the quality doesnt get any better-- it will actualy probably get worse. if you are trying to burn to dvd it doesn't need to be mpeg-2- dvd studio pro accepts mpeg-1 files as well.
    As below, so above and beyond, I imagine
    drawn outside the lines of reason.
    Push the envelope. Watch it bend.
    Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind.
  4. Member Treebeard's Avatar
    Aug 2002
    DOUBLE OOPSS
  5. I am trying to burn a dvd through dvd studio pro but I have no idea how to...I called toast and they said by me putting an mpeg file in toast it would not convert to a vcd. When I did that I wasted a dvd that turned out to be a vcd. Toast said to make a video ts folder or file and I have no idea how to do it, so if you can please help me I would be gratefull!
    7th layer of hell
    you need to use sizzle or dvd studio pro to make mpeg-1 or 2 files into VIDEO_TS/AUDIO_TS folders that you can drop in toast in and burn.. but when you have mpeg-1 you DONT need to convert to mpeg-2 to burn as a DVD- that is a common misconception.
  7. I know I have to make those files but how would I do it...especialy from an mpeg file?
    7th layer of hell
    honestly-- if you have dvd studio pro or sizzle just read the instructions-- its not that hard, its too well documented in so many places that i just cant justify typing it fully out
  9. I should just search in a search engine, by the way who makes sizzzle?
  10. can I work with an mpeg on sizzle or dvd studio pro to make a dvd, if I can how would I do it or use it? Thanks
