When joining dvd mpeg2 files in TMPGEnc after I go into merge and cut should I select Mpeg2 super video cd or mpeg2 program as TYPE??? I'm kinda confused as to why there is no mpeg2 dvd option and I definitely wanna burn to dvd NOT svcd and don't want to waste any dvdrs so someone please help me out. thanks!
well, I just chose the svcd option and then after I joined everything I converted the whole thing to dvd mpeg2. I'll just assu,e this is the best way if no one tells me otherwise. Worst case scenario is just more encoding time. Oh well atleast it works.
I use mpeg2 program for DVD file. the output file works fine for Ulead DVD workshop. the only problem is very diffical to locate the exact frame I want to join or cut. because TMpenc use different time code format? can anyone help? please.
Problems joining multiple MPEG2 files together.
By MagicPockets in forum Newbie / General discussionsReplies: 3Last Post: 30th Jan 2010, 09:47 -
need joining of 2 mpeg2 files.
By snafubaby in forum EditingReplies: 3Last Post: 21st Dec 2008, 16:51 -
Joining Mpeg2 files from the command line
By roden in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2007, 09:02 -
joining DVD mpeg2 files without re-rendering
By cheeseplease in forum EditingReplies: 4Last Post: 10th Aug 2007, 12:10 -
programm for joining mpeg2 files without decoding and artifacts
By mb508 in forum EditingReplies: 1Last Post: 7th Aug 2007, 06:51
