Hi All!
I decided to give CCE a go to encode my dv footage to mpeg-2. I downloaded the trial from the web and installed it. All has been working fine (except the CCE logo on the footage but this is a trial) but today i went to start the program and the program appears in the task bar, but the program doesnt appear on the desktop - i cant see it!! I checked the windows xp task manager which says its running. I also tried right-clicking the taskbar entry and selected move and put the mouse to the middle of the screen to see if it was hiding off-screen somewhere, but it isnt!
Anyone know what is wrong with CCE? I have version 2.66.01.07 SP (trial)? Does it expire after so many days and stop the main graphical user interface from being visible or is it something else?
Cheers all!
Thats a new one on me. I take it Alt-TAB didn't yeild any better results?
Using the MOVE option, you should try the Arrow Keys. You can also try right clicking on your start bar, and selecting one of the TILE WIDOWS options.Impossible to see the future is. The Dark Side clouds everything... -
ALT-TAB worked! many thanks!!! how weird huh!?!
To everyone on the forum, have a good xmas and a happy new year!
first time problem : can't find boot dsk on startup
By beavereater in forum ComputerReplies: 22Last Post: 24th Jun 2011, 16:09 -
XP OS selection at startup.....
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2009, 00:55 -
pc startup problem
By janefield in forum ComputerReplies: 3Last Post: 22nd Feb 2009, 11:09 -
Errors on startup
By johnbrigden in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd May 2007, 05:14 -
Error on startup
By bush in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 22nd May 2007, 18:30
