I am getting an error message while trying to burn Digital Stiil pictures to CD-R. It says "Could not complete last command - Internal software error DVDerr-19024.
I am using Sonic MyDVD! which came with my Cendyne Dvr-105!
Please help!
Thanks,
Bob
Welcome to my world, I have the same hardware and software and encounter the same problems. Sonic mydvd socks. What you may want to do is uninstall the reinstall the software. Hope this helps, if it doesn't go down to your local compusa or bestbuy and buy another dvd authoring software.
I will give it a try! It's strange because the first time I tried it it worked great making 1 menu! Then I tried to make multiple menus - due to limitation of only 99 photos per.. thats when I received error message?
Bob
Originally Posted by gabez -
Bob another thing that you may try is, create all your menus, selected the first menu the hit the burn button, make sure you are using a blank CD-R, that should create all your menus for you. It may take a while so be patient.
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
Nero Error Msg - 'Prepare Session Failed'
By Dieseldog in forum Authoring (DVD)Replies: 0Last Post: 19th Dec 2011, 06:38 -
error msg when try to record on drw-500
By harryb in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2007, 23:57 -
large file size when importing small video clips into Sonic MyDVD
By artistream in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2007, 19:48 -
TMPGenc just closes - no error msg - no rhyme or reason! Help please.
By brightsun23 in forum Video ConversionReplies: 3Last Post: 15th Jun 2007, 11:42
