I have been Racking my brain trying to make a photo vcd with nagivable menus for each photo album slide show.I have tried almost everything from ulead dvd pictureshow that is a great program but isnt compatible with my dvd arrhh. I then Tried to make a simple menu using the tutorials provided buy vcd help for vcdeasy this would have been great if vcdeasy worked with my PC, the aspi drivers would not work and when I applied the patch to force the drivers to be recognised it didnt work either.(yes norton was off when I updated the aspi force drivers if ya asking)
I evan tried to use the create dvd function in mgi videowave 5 with slideshow files already converted to mpg movies and no luck there either.I wont evan go into TSCV as I dont want to get a headache.
Can anyone please tell me any programs that will acive the affects Iam after ?
Thanku dan[/b]
I needhelp with vcds
For ultimate customabillity, you will need to author your VCDs manually: http://www.michaeltam.com
There is no "easy" way.
Regards.Michael Tam
w: Morsels of Evidence -
BTW, it is a common myth that CDRDAO is only "compatible" with a low number of burners. In reality, CDRDAO is compatible with essentially ALL modern IDE burners.
The problem is usually your ASPI layer. The best way is to download and install ForceASPI. Then REBOOT immediately.
In any case, if you want to try using VCDEasy, there is no need to use the included burning proggy (CDRDAO) if you can't get it to work. You can use VCDEasy / VCDImager to create an image of your VCD in CUE/BIN format and then burn that with a number of other burning proggies such as CDRWin, the newer versions of Nero, BlindWrite, etc..
http://www.vcdeasy.org has a number of strategies on burning CUE/BIN images.
Regards.Michael Tam
Its seems my problem is solved , I found a useful tutorial on making simple menus with nero(Is was right in front of my face dah), I used fly vcd or picture2vcd to make my mpeg slideshows with music and transition effects.
The Nero menu although limited in function, with a few snazzie graphics it came out with a polished and professional look that I was very pleased with.
I have the problem with my aspi drivers in easyvcd and I have downloaded the aspiforce drivers, and still no joy?I needhelp with vcds
Strange things happens in my VCD menu
By Douglas879 in forum Authoring (VCD/SVCD)Replies: 0Last Post: 28th Nov 2010, 04:07 -
VCD Menu Lite 2.00
By kbriggs in forum Authoring (VCD/SVCD)Replies: 4Last Post: 16th Mar 2009, 13:23 -
VCD on a DVD with menu?
By capman21 in forum Authoring (DVD)Replies: 5Last Post: 6th Apr 2008, 11:00 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36 -
putting a link to website on vcd menu. Is it possible.
By Mark-It in forum VCDEasy GeneralReplies: 1Last Post: 22nd Dec 2007, 00:08
