  1. Hello
    I have dvdx and TMPGEnc, both in th esame dir.
    I rip a movie from HD with DVDDecrypter and want to convert it to VCD with DVDx and frame serve it into tmpgEnc.
    Never had any problems in the past with it, but now I hav e a major ptoblem
    After reinstalling above SW, i cant get dvdx into frameserving to TMPGenc.
    In DVDx there is a thing in the output settings calles premiere plugin encoder and that used to be the place where my frameserver was, but now there is nothing left 2 choose.
    pleez help.
    thnx
    maarten
  2. The frameserver must bw in the same folder as the DVD.exe command. The server is listed as cm-videoserver.prm. If it is noth there, look in your DVDx folder. There should be a folder that says videoserver package. Open it up and you will find another folder labeled plugins. The videoserver will be there. If not just use the Aviwrapper as the server.
    8)
