Hi guys,
I'm using the latest TMPGEnc to convert to SVCD. What would give the the best quality output, either 2pass VBR 1950 or 2520 CBR? I notice you get less on a disc using the 2520 CBR but it encodes faster, but is this the better quality?
Thanks in advance & Merry XMas to all in this forum!
If you are making a standard SVCD (that is, you respect the max. bitrate limitations), then you won't get any better quality than 2500 kbit/s CBR (all other things being equal).
Regards.Michael Tam
w: Morsels of Evidence -
in general, CBR and VBR w/average at the same bitrate will give the same quality, but the VBR will be smaller file size.
what are you askin' me for...
I'm an idiot!
Whats the best screen recorder software for high quality video?
By peteman in forum Newbie / General discussionsReplies: 8Last Post: 20th Jan 2011, 13:51 -
Whats the best format for good video quality with reasonable file size
By hasanali00 in forum ffmpegX general discussionReplies: 2Last Post: 20th Feb 2010, 21:29 -
Whats a good analog to DV card with great quality?
By Onceler2 in forum Capturing and VCRReplies: 12Last Post: 2nd Dec 2009, 02:30 -
Whats Nominal bitrate?
By tb582 in forum Video ConversionReplies: 5Last Post: 18th Feb 2009, 13:31 -
Myspace allows 250 MB filesize video uploads. Whats Best Source Quality?
By hypnoticpimp in forum Video Streaming DownloadingReplies: 1Last Post: 29th Aug 2008, 00:14
