This question is for major and anyone else who can hazard a response:
I'm trying to encode a particularly difficult and long DVD. With ffmpegX-g, I get perfect sound sync, but choppy divX encoding. I was told that version g had problems with DivX encoding, and sure enough, it stutters. So, I used ffmpegX-d to encode. However, d doesn't seem to sync properly (it's making a 2+ hour move into a 1hr, 40min. movie). The encoding doesn't produce choppiness like g, but my guess is that it's not handling 3:2 pulldown properly. I've tried e and f, and they have the same bug as g.
So, my question is: How can I combine the proper mpeg-2 decoding in g with the proper divX encoding in f? If this is impossible, can I somehow alter the vob so that d doesn't need to worry about telecene?
Many thanks for your comments.
Waiting for a fix to the stuttering effect (linked to AC3 decoding), you can however obtain good results by following this method :
- decode first your audio into MP2 or other (this can be done very quickly by using ffmpegX and disabling "encode video").
- then select the extracted audio file in the "Add audio" field of the Audio tab, and launch the final encoding of both video and audio.
ffmpegX
By rideaugrrl in forum ffmpegX general discussionReplies: 4Last Post: 26th Oct 2010, 12:21 -
ffmpegx?
By creationx in forum MacReplies: 2Last Post: 28th Jul 2010, 12:15 -
FFMPEGx
By AnastasiaM in forum ffmpegX general discussionReplies: 1Last Post: 11th Dec 2009, 12:49 -
FFmpegX help
By Omipower in forum ffmpegX general discussionReplies: 4Last Post: 19th Aug 2008, 11:08 -
what about ffmpegx 1.0?
By imp in forum ffmpegX general discussionReplies: 8Last Post: 8th Nov 2007, 11:36
