When I try to create a VCD from a 500Mb MPG file it puts the .dat file in the SEGMENT directory in stead of the MPEGAV directory.![]()
With my PC I just double-click on the ITEM0001.DAT and I can see the movie, but I cannot see the movie with my DVD player.
I use Easy CD creator 5
pvrakking - what are the properties of you MPG file?
I could be barking up totally the wrong tree here, but perhaps EasyCD thinks it's a slideshow or something rather than a video file?
Is it a VCD compliant MPEG1?
cheers,
mcdruid. -
I would recommend another vcd authoring and burn tool like nero or vcdeasy.
But you could try "repair" the mpg before you add it in easy cd.
www.vcdhelp.com/faq#repairmpg -
Easy CD Creator has the peculiar habit of putting off-spec MPEG files into the SEGMENT folder when you use it to make a VCD.
Be that as it may, it does mean that your MPEG files are not VCD compliant...
http://www.vcdhelp.com/vcd
Make sure that your MPEG files have the correct settings if you want to make a VCD. Also, as the others have said, a better VCD authoring program is highly recommended.
Regards.Michael Tam
w: Morsels of Evidence
Batch "file creation from a text file, Placed into a created directory
By Muther in forum ProgrammingReplies: 5Last Post: 24th Sep 2015, 18:29 -
avseq01.dat file in mpegav directory
By ComputerScience in forum Newbie / General discussionsReplies: 8Last Post: 17th Jun 2011, 15:34 -
VOB2MPG 3.0 PRO - Output File Directory Suggestion
By SuperFist in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 3rd Jun 2009, 05:03 -
Windows cannot see VCD, directory blank, but plays okay?
By ianlin in forum Authoring (VCD/SVCD)Replies: 8Last Post: 3rd Oct 2008, 15:17 -
VIDEO TS Directory to a divx file...
By JustSomeGuy in forum Video ConversionReplies: 1Last Post: 6th Dec 2007, 14:10
