Hi,
Is there softwares to rip and convert DVD to VCD on a UNIX server (Solaris 7 or 8)?
Right now I'm using dvd2svcd on Windows, but I want to run it on a UNIX server due to better hardware which will make things run much fster.
I could not find something like that.
Thanks,
Idan
I think most people on UNIX platforms use transcode (http://www.theorie.physik.uni-goettingen.de/~ostreich/transcode/) for MPEG encoding. vcdimager (http://www.vcdimager.org/) is probably the best tool for VCD authoring, it's UNIX-native and was ported to Windows with cygwin32. Same for MJPEG Tools (http://mjpeg.sourceforge.net/), which you can use to create MPEG stills. dvd::rip (http://www.exit1.org/dvdrip/) provides a perl/GTK (so you'd have to install both) graphical front-end to the common tools. I'm not sure about actually ripping the DVD in Solaris, though.
A lot of those things say "Linux" but most of them probably don't use anything Linux-specific (tools to actually rip the VOBs off the DVD might, since they may deal with the hardware at a pretty low level). You probably do need gmake and gcc to compile, though. I wouldn't expect any of those programs to be available at sunfreeware.com, though some or all of the tools (like gcc and gmake) and libraries they depend on probably are.
It may or may not actually be faster, probably none of the tools are optimized for SPARC chips. If they have any optimizations it's likely to be in the form of x86 inline assembly. You may also find that some tools don't work unless you have x86+MMX because they use inline assembly and didn't bother to provide generic C versions.
How to create an ISO image file from a disc under UNIX.
By valeyard1492 in forum LinuxReplies: 11Last Post: 11th Sep 2009, 20:11 -
High-Resolution VCD/SVCD Stills on the UNIX Command Line
By sterno in forum User guidesReplies: 7Last Post: 20th May 2009, 13:16 -
Cutting video to several parts without encoding (on Unix system)
By Doctor_X3 in forum EditingReplies: 0Last Post: 23rd Feb 2008, 15:23 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
