Hi,
I'm about to buy a Sony DV camcorder, and as I understand it all I need to transfer the video from the camcorder to my PC is a firewire port. I was planning to just buy a standard PCI firewire card which cost peanuts! However, I've recently found out that you can buy 'DV Capture' cards that can cost in the region of £200+, and I'm worried that if I just buy a standard PCI firewire card, then I might be missing out on something if I don't get one these 'DV Caputre' cards. Can anybody explain what the benefits are of buying a dedicated DV Capture card? I already have excellent DV video editing software so that is not a problem. As far as the actual hardware goes, is there any difference between a standard PCI Firwire card and a dedicated DV capture card?
Your help would be much appreciated!
Merkin
The standard PCI firewire card is all you need for transferring DV footage between a camcorder and a PC. The DV capture card you mention most likely is able to convert analogue footage to DV - that's why it's more expensive. With this feature you can convert your old VHS tapes to DV. However, most Sony camcorders (especially the newer ones) can do this anyway - it's called analogue pass-through (although it may be listed as 'analogue in' in the camcorder brochure).
Originally Posted by sdmoore
Sony DCRTRV25E
If I get that and a standard PCI Firewire port, will I be all kitted out for both DV and analog video editing / capturing? I thinkthis camera has an analog input for the pass-through? -
I imagine the "E" in TRV25E stands for Europe in which case the "video in" and "DV in" must be enabled with a widget or certain codes.
See this thread:
http://www.vcdhelp.com/forum/viewtopic.php?p=390285&highlight=widget#390285 -
yg1968
This is sometimes true but for the camcorder in question (TRV25E) this is not necessary as, if you check Sony's UK website, DV-in is enabled as standard -
Yes, it seems that you are right:
http://195.2.39.25/dime/www/XX/en/homepage/products/camcorders/digitalvideo/DCR-TRV25/index.html
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 10:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 10:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
