I just encode some videos from my SVHS (RCA to PC) to a VCD usin the TMPG encoder, then, when I playback the VCD in my standalone VCD connected to my TV it looks like in a bad tranfer rate or something, like in slow motion or with to few FPS...
What can I do?
Greetings
SAMM![]()
(1) Did you load the VCD template with TMPGEnc?
(2) Does it look okay on your PC?
Regards.Michael Tam
w: Morsels of Evidence -
Yes,.. I just loaded the VCD tamplate to encode.
And, yes, the VCDs created run just fine in my PC, but slow in any VCD player (not yet tested in a DVD player ...)
Then, when I use XingMPEG encoder instead TMPEG encoder the motion is fine, but I get audio out of synch.
Greetings from Mexico Citty.
HelliXSystems
Since you are capturing video, I assume that you must have used an intermediary AVI first. What codec did you use? DivX? MP3 for audio?
There can be problems converting DivX to MPEG and I suggest that you read some of the guides on ways to overcome them...
Alternatively, try capturing with a codec that is a little more friendly to encode with (e.g., a MJPEG AVI codec or HuffyUV).
Best of luck.Michael Tam
Hello, thanX for replying,...
I'm using my ATI capture software, wich captures to AVI & MPG1 & 2.
I am capturing to MPG1 then converting to VCD stream using Xing encoder & TMPGEcoder, then burning with EZCDCreator 5 (with XP patch)
I don't know what I'm doing wrong,...
Greetings
smooth slow motion
By nitrobaorder in forum EditingReplies: 22Last Post: 18th Oct 2010, 07:19 -
How to make slow motion???
By X_Splinter in forum EditingReplies: 7Last Post: 8th May 2008, 17:01 -
Make slow-motion
By David_UK in forum Newbie / General discussionsReplies: 15Last Post: 28th Nov 2007, 01:44 -
Slow motion
By Pliny in forum MacReplies: 7Last Post: 7th Aug 2007, 01:02 -
Slow Motion
By sbuckmybballs in forum Newbie / General discussionsReplies: 6Last Post: 21st May 2007, 03:16
