I use BeSweetGUI0.6b66 to convert mp2 file with samping rate 44.1 KHz - 224Kbits bitrate TO 48KHz with 224Kbits bitrate unchanged.
I need only to convert sampling rate to 48KHz for DVD. I set the settings correctly and I get the mp2 file with 128Kbits bitrate! Where do I check for the settings that might be incorrectly set by default or something like that? Please advice some actions.
THanx
=[ vinchi007 ]=
vinchi007 - i think you'll have to give a little more detail of what settings you're using for anyone to be able to help.
BeSweet has a lot of different settings & options - we can't guess what you think are the right ones, and then tell you if they're not!
cheers,
mcdruid.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
RipBot264 Audio Problem (no audio)
By fefalas in forum Video ConversionReplies: 9Last Post: 8th Apr 2011, 11:39 -
Help With Audio Problem please!
By heidilynn08 in forum AudioReplies: 3Last Post: 16th Dec 2010, 12:08 -
problem with Audio
By cgguy in forum AudioReplies: 1Last Post: 14th May 2007, 07:48
