hi
apprec any help here:
am using picturetotv to generate vcd of stills with transition effects and music; the process results in a bin/cue file system; question: how do i then sequentialize this with another video stream (sequence of short avi video clips converted to mpeg by arcsoft video impression)?
objective is to finally burn only 1 vcd
thnx
get nero 5.5. that'll do everytin for ya
*You cant put avi's on a VCD, convert them to MPEG firstWanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
Um, Nero isn't going to help you here.
It sounds like you need to extract the MPEG file out of the CUE/BIN file and then make your own VCD (e.g., with additional clips / menus). You can do so with VCDGear or VCDXRIP. You can use VCDImager Tools GUI as a GUI to VCDXRIP ( http://www.michaeltam.com/vcdimager_tools_gui.html ).
Once you've extracted the video clip of your photo slideshow, you can use any other VCD authoring program (e.g., VCDEasy / VCDImager or Nero).
Regards.Michael Tam
w: Morsels of Evidence -
thnx torro
- am actually using nero 5.5 to do the actual burn
- yes, converted the avi to mpeg1 already thru arcsoft video impression
question: now how to thread together the generated bin/cue, followed by the mpeg?
thnx virtualis
is there any way to manioulate/edit the bin/cue? really like the resolution generated by picturetotv; problm is that it is a one-stop process, no way that i can see to intercept; dont really want to reverse and re-extract the mpg
thnx again one and all -
Originally Posted by synpc
You can use VCDGear or VCDXRIP (with VCDImager Tools GUI) to extract media files out of the CUE/BIN image.
Regards.Michael Tam
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 09:55 -
VCD burning freeze
By Douglas879 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 28th Nov 2010, 15:23 -
Burning .srt along with .avi onto a VCD
By wox in forum Authoring (VCD/SVCD)Replies: 3Last Post: 5th Jul 2008, 08:35 -
Help burning vcd
By Reds in forum Authoring (VCD/SVCD)Replies: 3Last Post: 8th Feb 2008, 07:20 -
vcd burning
By srckaimal in forum Newbie / General discussionsReplies: 26Last Post: 6th Dec 2007, 06:23
