I have a BIN & CUE of a movie, it is an SVCD. I've opened it up with NERO, but when I click it to burn, it always says that "There's not enough room on my CDR". I'm using an 80Minute/700MB CDR [Phillips Brand]. What am I doing wrong, also when I discard the file, it shows that the BIN is about 800MB, no wonder it won't burn... how do you burn an SVCD?
Please help?!
I have to ask this, but when you go to burn the CD in nero, do you go to file and then click "burn image"? or are you trying to burn the bin/que as a file(like going through the wizard or something).
Outside of that you should have no problem burning the 800 meg file. I have 820+ in the bin queue and they will burn fine. -
"IF" your burner supports it, set nero to overburn. If it does not support this function, you could possibly damage your device.
Your 80min CD is rated at 700mb mode-1, VCDs and SVCDs are burned mode-2. That same 80min CD when written to mode-2 holds 800mb. Therefore if the file 800mb or less you should not have to enable overburn.
Yes, a BIN/CUE file is an image. In Nero select Burn Image, then change to all files and select the CUE file. -
Make sure you update to the latest version of Nero. Some of the older v5.5 versions do not support burning CUE/BIN images properly and from memory, had similar problems like the one described.
Regards.Michael Tam
w: Morsels of Evidence
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 20:33 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
