Hi, I'm trying to do simple capture on a WinXP machine using a borrowed Pinnacle PCTV Pro card. I installed all the latest drivers that are supposed to be compatible with XP. I am using Virtualdub, and I can see the video and hear the audio when I go to Capture AVI... But when I try to start capturing, it gives me the following error:
Error 424: Cannot open the video input device.
I know this is an ancient card, but it would be nice if I could use it for my simple needs. Any advice?
Thanks,
Mike
The most likely explanation is due to the drivers. The version 5.x drivers for the PCTV pro are WDM drivers, which are necessary for XP. However VirtualDub requires older VFW drivers.
If you check other posts here you can search for a few alternatives.
1) An alternative capture program that works with WDM drivers, I believe virtualVCR is one free alternative.
2) Search for posts which list where you can find a VFW WDM "wrapper". That should allow you to use VirtualDub.
3) Look for http://btwincap.sourceforge.net/ & there's generic 3rd party drivers there which I believe will also allow you to use VirtualDub.
However you'll need to find other 3rd party programs to operate it as the pinnacle app's don't work with those drivers.
Hope this helps!
Yup, that fixed it. VitrualVCR workes. Thanks a lot.
Of course, now: I'm running into synch problems with the audio/video.
Any suggestions for that?
Sorry for the delay in replying, hope you still have it ot use. Unfortunately, the V5.x WDM drivers have proved a real problem.
Thats why I pointed to option 3 before, although you'll lose use of the app's s/w.
You can give these two areas a try & see what other users have come up with. There seems to be a suggestion that depending on what capturing software used the sync issue problems can go away....
http://webboard.pinnaclesys.com/read_messages.asp?UpdateOrder=1&Start=0&AscDesc=asc&We...=&cntThread=50
And the general PCTV board
http://webboard.pinnaclesys.com/read_forums.asp?WebboardID=1&SectionID=80&lng=1
pinnacle pctv 310i
By marc21782000 in forum Capturing and VCRReplies: 10Last Post: 4th Jan 2010, 03:30 -
Pinnacle PCTV HD Pro Stick, my experience
By vhelp in forum DVB / IPTVReplies: 46Last Post: 14th Oct 2009, 20:36 -
What software for Pinnacle PCTV HD?
By tomreedtoon in forum Capturing and VCRReplies: 10Last Post: 9th May 2009, 07:14 -
Audio problems with Pinnacle PCTV HD Pro Stick.
By cactusjack310 in forum AudioReplies: 0Last Post: 21st Jan 2008, 18:16 -
Which is best, Pinnacle 110i or PCTV Pro PCI
By brvignesh in forum Capturing and VCRReplies: 23Last Post: 28th Nov 2007, 23:40
