I get an error (spruce.exe has generated error’s)
After 99% when compiling my files, Seems to create everything but an…IFO, All vob’s are present.
Is there any way to edit the original (IFO) to work with my project?
Thanks for any help
its complete at 99% for some reason, not sure why its
does that...everyone has same problem -
Thanks for your fast reply……. so your saying all have to do is burn my auto_ts and video_ts?
The newbie dvd2dvd-r guide state’s to use ifoedit and annotate the original Ifo settings and make change the one spruce created. (spruce ifo missing)
Is this not necessary? -
Spruce should create the .ifo for you, my version completes everything fine it doesn't hang at 99% then you edit the .ifo with ifoedit as spruce only supports 4x3 so you need to change it to 16x9, letterboxed etc as per original .ifo
Use create title set in Spruce instead of disc image as this works perfectly, creating the video_ts directory on your hard drive then burn with Nero, Prassi etc.
If your .ifo is missing i believe you could use ifoedit to create one for you.
.ifo/.sup subtitle pair - what's in the .ifo?
By MilesAhead in forum SubtitleReplies: 2Last Post: 4th Mar 2010, 23:02 -
timeline problems - IFO mode only (VOBSET works)
By charliem in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 5th Aug 2009, 05:32 -
Spruce Encoders
By zerohash in forum Authoring (DVD)Replies: 1Last Post: 12th Sep 2007, 05:10 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 13:38 -
vob/ifo to xvid audio sync problems.
By spiked in forum Video ConversionReplies: 4Last Post: 21st Jun 2007, 17:19
