I have a Samsung P421 dvd player, that was advertised on the box, and
on web site reviews to play SVCD. User reviews have said they have
played SVCD as well.
In the manual it states that this player cannot play SVCD and when I
do put in a SVCD disk it indeed comes up with "this player cannot play
this disc." I tried a few more but the same result.
Does anyone have any insight on what this may be. Is there anything
special about copying svcd discs. Is there a hack or workaround.
Samsung claims that it will not play burnt svcd only store bought.
This doesnt make sense to me and is contrary to what many of your are
playing.
Please email back to digital6@shaw.ca
Please refrain from posting the same question in multiple forums in the future. Once is enough.
As to your problem, CD-R and CD-RW compatibility is a separate ability to VCD and SVCD compatibility.
It sounds like your player is not CD-R/W compatible. As such, you may have to experiment with different brands of CD-R media to find one that works. CD-RW often works better in these cases.
A way of testing CD-R/W compatibility is to burn an audio CD on the same media type. If it plays flawlessly on the player, it indicates that the drive can read the disc well.
As for your manual explicitly stating it to be NOT SVCD compatible and the adverts on the box claiming it does, if this is true, then I suggest you get a refund and buy a better player. If the manual is actually correct, then it is a case of bait advertising and you shouldn't stand for it.
Regards.Michael Tam
w: Morsels of Evidence
Samsung DVD P230 player gets confused
By ckmoore in forum DVD & Blu-ray PlayersReplies: 0Last Post: 22nd Mar 2012, 20:11 -
Samsung HR775 DVD player
By akiskekridis in forum DVD & Blu-ray PlayersReplies: 2Last Post: 1st Mar 2011, 10:03 -
need region free hack for samsung dvd player p171
By oztib in forum DVD & Blu-ray PlayersReplies: 23Last Post: 9th Aug 2010, 09:21 -
Samsung P-191 DVD player Firmware problem
By stfly in forum DVD & Blu-ray PlayersReplies: 0Last Post: 19th Jun 2010, 10:17 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 10:15
