  1. I am having a problem when ecoding DVD video from DV AVI. I get flicker on motion when deinterlace is activated and no flicker but artifacts when it is disabled. What are the optimal settings for DVD encoding that will eliminate this problem. I cannot use Virtualdub as it will not work with the Dazzle Card.
  2. In TmpGenc make sure the following settings are set this way:
    On the settings Video tab:
    Encode Mode: Interlace
    On the Advacned tab:
    Video Source type Interlaced
    Field order Bottom field first (field B)
    Source Aspect ratio: 4:3 (NTSC or PAL as appropriate)
    If you still have problems, try reversing the field order.
