I was happily making SVCDs using the .mov -> SVCD (NTSC) quick preset. I must have changed something, because now the SVCDs I make do not play in my Magnavox player. My old ones still play, and my new ones play using vlc. I even re-burned the files img files from ffmpegX from before I messed something up, and they play. I am using ffmpegX 4d on OS X 10.1.4. Here is my terminal output:
pbpaste | sh
% pbpaste | sh
## Component Manager: somone is attempting to find symbols in a component alias of type (regR/carP/x!bt)
++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
++ WARN: [mpeg2enc] If you're not using vcdimager you may wish to turn this off using -d
INFO: Opened WAV file, freq = 48000 Hz, channels = 2, bits = 16
INFO: format = 0x1, audio length = 3055680 bytes
INFO: slots/frame = 731
INFO: frac SpF=0.429, tot bitrate=224 kbps, s freq=44.1 kHz
INFO: Fractional number of slots, padding required
INFO: System is big endian
INFO: Avg slots/frame = Inf; b/smp = Inf; br = Inf kbps
INFO: Encoding with psychoacoustic model 2 is finished
INFO: The MPEG encoded output file name is "/Volumes/TEMP/video/small2/iDVD_not.mp2"
INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
INFO: [mplex] File /Volumes/TEMP/video/small2/iDVD_not.m2v looks like an MPEG Video stream.
INFO: [mplex] File /Volumes/TEMP/video/small2/iDVD_not.mp2 looks like an MPEG Audio stream.
INFO: [mplex] Found 1 video streams 1 MPEG audio streams and 0 AC3 streams
INFO: [mplex] Selecting SVCD output profile
INFO: [mplex] Scanning for header info: Video stream e0 (/Volumes/TEMP/video/small2/iDVD_not.m2v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 480
INFO: [mplex] Frame height : 480
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 29.970 frames/sec
INFO: [mplex] Bit rate : 2500000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (/Volumes/TEMP/video/small2/iDVD_not.mp2)
INFO: [mplex] AUDIO STREAM:
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 44100 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 2780000
INFO: [mplex] target data-rate specified : 2788800
INFO: [mplex] Setting specified specified data rate: 2788800
INFO: [mplex] Sectors = 78 Video delay = 46800 Audio delay = 46800
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 235520 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] Scanned to end AU 476
INFO: [mplex] STREAM e0 completed @ 476.
INFO: [mplex] STREAM c0 completed @ 608.
INFO: [mplex] Multiplex completion at SCR=1473000.
INFO: [mplex] Video e0: buf= 220617 frame=000476 sector=00002124
INFO: [mplex] Audio c0: buf= 2633 frame=000608 sector=00000195
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 605832 bytes
INFO: [mplex] Sequence headers: 33
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 477
INFO: [mplex] No. Groups : 33
INFO: [mplex] No. I Frames : 33 avg. size 20742 bytes
INFO: [mplex] No. P Frames : 127 avg. size 11611 bytes
INFO: [mplex] No. B Frames : 317 avg. size 8500 bytes
INFO: [mplex] No. D Frames : 0 avg. size 0 bytes
INFO: [mplex] Average bit-rate : 2436000 bits/sec
INFO: [mplex] Peak bit-rate : 2479600 bits/sec
INFO: [mplex] BUFFERING min 26 Buf max 118247
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 445440 bytes.
INFO: [mplex] Syncwords : 609
INFO: [mplex] Frames : 348 padded
INFO: [mplex] Frames : 261 unpadded
INFO: [mplex] BUFFERING min 17 Buf max 744
INFO: [mplex]
INFO: [mplex] MUX STATUS: no under-runs detected.
(Super) VideoCD xml description created successfully as `/Volumes/TEMP/video/small2/iDVD_not.xml'
++ WARN: initializing libvcd 0.7.12 [darwin5.2/powerpc]
++ WARN:
++ WARN: this is the UNSTABLE development branch!
++ WARN: use only if you know what you are doing
++ WARN: see http://www.hvrlab.org/~hvr/vcdimager/ for more information
++ WARN:
Encoding complete!
I don't think that ffmpeg likes file names with things like "_" in them.
-Squeed
http://www.squeeds.com
VCD & SVCD Support For MAC
Squeed
Thanks for the suggestion. I tried again without underbars and got the same results. Could I have messed things up by changing which application should be used to open either the .m2v, .mp2 or .mpg files. For a while, I thought I would preview my SVCDs by watching them in VideoLAN Client (vlc), so I changed one of the above files so that when I dragged the file over to the vlc icon, it would open up. In the Finder, I get this for the files:
.m2v MPEG-2 Video File
.mp2 MP2 Audio File
.mpg MPEG Movie
The .m2v file opens with vlc, the .mp2 with iTunes, and the .mpg file with QuickTime.
After days of experiments (including re-installing my OS (10.2), all of my video-related applications, and Toast), and burning about 40 coasters, I stumbled on the answer to my question. NOTHING WAS BROKEN.
After making 4 half hour SVCDs, I had decided to experiment to find a way to reduce/eliminate the blockiness problem many others are reporting. In doing this, I was working with a 10 second clip. I burned some SVCDs, and my DVD player (Magnavox MDV 450) wouldn't play them. It still played my half-hour SVCDs. I re-burned one of them and it played. I tried many other experiments, including reinstalling software, and none worked on my DVD player, but all played using VLC. So I gave up and decided to continue with my project of moving home analog videos onto SVCDs in half hour chunks. If I could only play them on the computer, then so be it. At least I would have another backup of my aging video tapes. To my surprise, IT WORKED.
My conclusion: Apparently, my DVD player cannot read/find files if they are too small. I haven't found the smallest size it will read, but .img files that total about 3MB are too small.
-Mike
Layer break issues
By pinetop in forum Newbie / General discussionsReplies: 1Last Post: 8th Jan 2010, 20:09 -
did I break FAVC?
By brentonboy in forum Newbie / General discussionsReplies: 4Last Post: 20th Nov 2007, 05:00 -
Help break my VCR
By NightFire in forum RestorationReplies: 9Last Post: 22nd Jun 2007, 18:12 -
Retail Layer Break and Imgburn Layer Break..the same?
By Moontrash in forum MediaReplies: 2Last Post: 14th Jun 2007, 13:27 -
DL (+R) break point
By pheldd in forum MediaReplies: 5Last Post: 10th May 2007, 11:15
