I tried split JPIII (mpeg-1 352x288,25fps)with Tmpgenc & VCD Cutter, which I downloaded of the internet. With Tmpgenc the second file has no sound. With VCD Cutter the second file when you try to play it says No Combination filters can be found to render the stream and it wont play. Also when I try to encode it with Tmpgenc it will not load, but as long as I don't cut the file it will play. What should I try next. Please someone, anyone have any suggestions
JohnJohn1999
