I want to backup all my Hi8 tapes to DVDR. I want the best quality without wasting space, either on my Hard drive or on the DVDR. My question revolves around only one aspect.
What resolution do I capture at? I am using Virtual dub with Huffy compression, which I will later use to encode in TMPG.
720X480, 704X480, or 352X480. I want the best without "OVERKILL".
Obviously 720X480 then encode at 9800 bitrate would produce the best results. However, I think we can reach the "peak" quality (since source is HI8) at lower resolutions and bitrates.
Thanks for any input.
bbeiler,
A similar thread was started a while ago.
I'm sure it contains all the information you are after - heck, it even mentions "OVERKILL"
http://www.vcdhelp.com/forum/viewtopic.php?t=127563"speed's just a question of money. How fast can you go?" - Mad Max, 1979
Video8/Hi8 playback/capture options
By HDClown in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 21st Dec 2025, 05:00 -
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 11th Jun 2011, 00:05 -
No audio capture from Hi8 camcorder to PC
By dimtechno in forum Capturing and VCRReplies: 0Last Post: 20th Mar 2009, 16:50 -
Capture Hi8 using what resolution?
By chrishallowell in forum Capturing and VCRReplies: 2Last Post: 3rd Oct 2007, 12:57 -
Choppy capture from HI8 in Premiere
By tmann in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2007, 15:24
