  1. hi ppl
    just wondered if any1 has figured out how to disable the buttons in the dvd so the parts which dont work anymore, like the extras when pressed wont stop dvd playing, if so could u plz help me or tell me where to find guide
    cheer
    john
  2. Just use IFOedit, load up the .ifo, find the VOBS that are the junk you removed, then use the "DELETE PLAYBACK" button. Save your new IFO.
    Get VTS Sector. DONE.
    Easy. Good Luck.
  3. Intesting. I wasn't aware that's what that did. Thanks I'll give that a shot.
    How about this one? I assume you can still move the cursor over the part that was removie just when you press enter/select nothing happens. How about making it so the cursor doesn't go to that spot anymore and skips over it? Can this be done with IFOEdit?
    I have some DVD's I bought when I was in Russia and they have some options in the menus that you can't get to as they were probably removed. Did they use something like IFOEdit to do this? I haven't had any luck if they did.
    Spudz
