I'm probably missing something, but here goes:
I'm capturing from my video source, which will be Hi8 when I'm ready, but using the composite video output from my satellite dish for testing purposes. Capturing with Scenealyzer using type 2 (720x480 NTSC). The resulting AVI file quality is excellent. Then using TEMPEnc Plus to convert to MPEG-2 in preparation for DVD authoring.
I'm having two problems, both happen with the original camera pans or zooms. The video gets real choppy, or there is some really annoying horizontal lines. It looks kindof like your watching TV on a non-terminated line if that makes any sense.
I thought that switching from CBR ot VBR would help. I've also done some other tweaking to no avail.
Any idea what the problem is?
Possibly an interlacing problem.
When encoding in TmpGenc, click settings and go to the advanced tab. Make soure Video source type is set to interlaced. If you still have the same problem, change the field order from whatever it is set to, to the alternative value. -
I can think of two possibilities. Either your field order is wrong, or your simply seeing interlacing. It's possible you can remove it, if the source has been telecined.
www.lukesvideo.com
Check the 'Classifying Hi-Res' section. It will help you to identify if your video can be inverse telecined (IVTC) to remove those extra interlaced frames. You save both space, and bitrate by doing this. If your source is true interlaced material, then you can try to deinterlace it via various filters/methods. The guides section has a multitude of ways you can do this, but it's not strictly necessary, as the final product, when viewed on your television will usually look fine. It's only when you view these on a PC, that you see both fields at the same time, and notice the interlacing at all.Impossible to see the future is. The Dark Side clouds everything...
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
wavy line distortion in .avi file - how to remove
By abeelandig in forum Video ConversionReplies: 2Last Post: 21st May 2009, 03:01 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
Fixing AVI Audio - modular distortion?
By 00Billy in forum AudioReplies: 1Last Post: 3rd Nov 2008, 09:27 -
Philips PET725/78 - Distortion when .avi is "wider" than wide scr
By xXxAlvoxXx in forum DVD & Blu-ray PlayersReplies: 2Last Post: 5th Jun 2007, 12:37
