I want to be able to use the skip frame button without it going all the way to the end of the movie.
I've asked the same question and i was told: "It's not possible"
The only thing you can do is fast forward and rewind threw the vcd.
Only God Can Judge Me!!! - 2pac -
U can do it, there are a couple of ways to do it for vcd and svcd, the easiest way is probably to use VCDIMAGER and one of the GUI's for it, just simply click on the mpeg file u want to use, and indicate at what time points you want the 'chapter thingys' to be at it will generate a CUE and a BIN file, just burn this with cdrwin
Pz -
So use CDRWin huh? aight lemmie peep that and see if it works. Thanks for your help
You record it as separate MPG files, with the splits at scene changes.
It's better to use VCDImager to add 'chapters' at the I-frames then to make several MPEGs as most players pause slightly between tracks.
VCDImager GUI (or for MPEG2 files) TSVC (www.ttool.org) will do the job seamlessly(sp). -
yea its a matter of xml
you can scan through the video and then tell it to put points in specific times. so to skip to the indicated point would be either through the |> skip button or the menu navagation.
thats only if you want it to go to "specific" parts in the movie a la dvd.
I think there is a gui that does that but i havent checked it out yet too busy studying xml.
hope that helps
F1!! F1!! F1!!!
How do I retain Chapter Points from Movie? [DVD Lab Pro 2]
By SupaDupaMonkey in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2009, 19:56 -
Any way to create streaming video with chapter points or menu navigation?
By Persistence in forum Video Streaming DownloadingReplies: 3Last Post: 5th Jun 2009, 21:24 -
How would I create points or chapters throughout my mp3 audio file???
By Hittz in forum AudioReplies: 5Last Post: 17th Feb 2008, 23:18 -
How to create small clips from a movie!
By unstopabl3 in forum Newbie / General discussionsReplies: 3Last Post: 27th Dec 2007, 05:34 -
Create movie in Flash CS3 ?
By lordsmurf in forum Newbie / General discussionsReplies: 0Last Post: 13th Nov 2007, 11:08
