I have burnt two VCD's. The first contains 17 files and the second 18 files (both of them is alltogether about 700mb). I've tried to play them in both Windows mediaplayer 7.01 and in the PowerDVD, none of them works. In WinDVD all the files of the both records works except for the files 9-14 (no picture only disted noise). The strange is that there are different files on place 9-14 of the both records (so it's apparently not the files themselves that are bad). I read at http://www.vcdhelp.com/play (at the bottom) that one has to install a virtual driver "SCSI1HLP.VXD" in the Window's \SYSTEM\IOSUBSYS folder. I can't find IOSUBSYS at all in my Windows 2000 pro. I'm using Nero 5.5.9.9 and HP9310i burner.
Thanks for help!
Both VCD's worked (even files 9-14) for 100% at my friends house in the Windows mediaplayer! They are using Windows millenium.
How come I have the problem, described in the post above at my place? (yes, I've tried VCD players too)
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 11:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
