i use a voodoo 3500 tv card
when capturing and per this web sites surjested settings (huffyuv) the video it produces say for example 10 second clip the video stream finishes after about 7-8 sec while the audio continues to the end
how do i correct this
How big is your AVI?
have you enabled multisegment capture under capture?
This option will split the AVIs into 2GB-Files. The AVI-file-format doesn't support bigger files.
mfg
TKS -
no this happens what ever the size like the example where i caputered a 10 second file (avi) the image runs a about 120% and the audio at 100%
have you tried adjusting the frame rate? go to video->framerate and check "change so video and audio durations match".
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 13:24 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 03:46 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 13:08 -
Simple Virtual Dub Problem...
By tetzy in forum EditingReplies: 2Last Post: 22nd Feb 2008, 19:49 -
Ripping DVD & Virtual Dub Problem...
By Chana1 in forum DVD RippingReplies: 7Last Post: 8th Jun 2007, 07:45
