I am new to this burned a few movies then watched them and i am getting Flickering squares in there not all the time but it comes alot too.
Is it normal for VCD? or there is a way to fix it?
Thanks Alot
On the face of it, it doesn't sound normal...
However, can you describe what you mean in more detail?
Regards.
Michael Tam
w: Morsels of Evidence -
Okay, you are seeing macroblocking in the image.
Macroblocking is simply a part of MPEG-1 at VCD bitrates, but may be exaggerated by a number of things:
1. Poor quality encoder
2. Poor quality source (i.e., lots of noise)
3. Difficult section of video to encode (e.g., fire, explosion, crowd of moving people)
4. Poor quality decoder
5. High resolution screen (e.g., PC monitor)
6. Incorrectly set gamma for you screen
Thus, to obtain the best video quality for your VCDs and to keep visible macroblocking to a minimum, you should use a high quality encoder (e.g., TMPGEnc or Panasonic MPEG Encoder), have a clean video source (e.g., DVD rip), use a high quality decoder (e.g., hardware MPEG decoder card or stand-alone VCD or DVD player), play the VCD on your TV, or if you have to play it on your PC monitor, make sure that the gamma is set correctly (there is a tool available when you install Adobe Photoshop).
Regards.
Michael Tam
VHS tape displays red saturation during normal playback only
By mlong30 in forum Capturing and VCRReplies: 2Last Post: 25th Oct 2008, 14:11 -
A font with only squares, how to create?
By sybariten in forum ComputerReplies: 3Last Post: 21st Feb 2008, 16:38 -
Squares Appear When Playing Online Games - Resolved
By HacktheHacker in forum Software PlayingReplies: 6Last Post: 20th Jan 2008, 17:07 -
vcd playback - flickering picture on one dvd player, fine on another
By i_ming in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 08:41 -
3d Games Cause Large Squares on Screen - SOLVED!
By HacktheHacker in forum ComputerReplies: 11Last Post: 29th Jun 2007, 20:59
