i have 30 cdr's that i have done from my vhs home movies. all mpeg2, 352 x 480.
i have used the "vcd header trick" converting these mpeg2 files into a vcd so i can watch them im my dvd player (panasonic). however, images have strong block noises.
is it possible to convert somehow these non-standard mpeg2 files and then reducing the block noise? tmpgenc can do that?
The block noise is actually part of the MPEG now, and therefore part of the movie. Moving it to another format will just take the block noise to the new format.
Impossible to see the future is. The Dark Side clouds everything... -
tks for the reply, but i have tried the following options, with great
reduction on block noises:
1) apply dvd2avi on the mpeg2 file, open the resulting d2v & mpa files with tmpgenc, and re-encoded as a vcd mpeg1 standard, file size reduced from 28 MB (2 minutes sample) to 21 MB.
with this solution, some little block noise is present, but great quality was obtained with
2) applying dvd2 on the mpeg2 file (352 x 480, vbr 2000 medium), open d2v & mpa with tmpgenc and re-encoded as a cdv with 352 x 480, vbr 2-pass min=0, max=2520, med=2150). file size increazed from 28 to 38 MB (2 min. sample - about 45 min on a 80 min cdr). however video quality is really great!! -
just forgot to mention that i applied the "vcd header trick" to item 2 above.
also: computer time to re-encode:
1 above = 3 times the video time.
2 above = 13 times the video
remove noise and block.
By mathmax in forum RestorationReplies: 124Last Post: 21st Mar 2014, 16:51 -
To block sites
By Jomapil in forum ComputerReplies: 13Last Post: 24th Apr 2012, 20:12 -
Digital block out
By homie241 in forum RestorationReplies: 9Last Post: 21st Apr 2011, 07:40 -
Multi-colored block noise bug in Adobe Premiere - DV video
By tat2jr1 in forum EditingReplies: 0Last Post: 23rd Jan 2010, 03:20 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 01:57
