I am looking for a DVD recorder that laso records in VCD and SVCD format.
Do you know of any.
qshartle
"Good Luck 007"
In Memory of Desmond Llewelyn -
Any of the DVD burners will do exactly what you want. Forget about the standalone DVD recorders, none of them can.
I should also point out that this is a software issue (you don't even need a DVD burner to create VCDs or SVCDs; a CD burner would do). -
I hate cpu dvd burners
They are way slow.
Plus i have a Mac(Yes i kno u hate them)
I just need a standalone recorder that does that.
Qshartle"Good Luck 007"
well don't plan on that to happen anytime soon if ever. if you are worried about scvd or vcds why not get a cd burner. you can get a good one for under 50 bucks and its fast. burn 700 megs in like 4 minutes............
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43
