Ok,
I converted a DiVx AVI into 2 files.
- M2V file
- MPG file
Popped these into DVD Maestro and compiled to create the VIDEO and AUDIO TS folders.
Tested the files from WinDVD player and pointed it to the above folders and it played perfectly.
I then burnt using NERO and played the DVD on my PC DVD Drive and this too worked fine.
However, when I put it into my standalone DVD it comes up with DISC Error.
Any pointers/suggestions.
BTW: I tried it on another standalone player and it seems fine.
What is your standalone player, and what media are you using. It would seem to me that your player has compatability issues with your media.
Hi Craig,
My Standalone player is
Panasonic NV-VHD1 Multi-Region
Plays back DVD, DVD-R, CD, CD-R/RW and MP3 discs
My Media is described below.
NEW! Infiniti™ WhiteTop® DVD-R 4.7GB Compax™ (25)
Exceptional quality 4.7Gb recordable DVD discs · Multi speed · Nicam Stereo compatible · Suitable for Digital TV · 25 spindle discs per pack · White Top · Fully tested and compatible with popular writers
Never had a problem with these media before, and the player is brand new, but this may be the problem. -
...how was it burned (if you used NERO)? Was it by DVD-Video?
My Panasonic set-top would only accept DVD-Rs burned as DVD-Video. There were some instances that I had to burn it as ISO, and that won't play on my set-top (luckily I tried it on DVD-RW first), but played well on my PC. -
Hi,
I do all my burning with NERO, and yes, I make sure that I set it to the DVD-Video on the Wizard. As I said, plays on a lot of other dvd players, just not this one
I simply drag over the Video and Audio folders like normal and hit burn -
Originally Posted by darkufo
Now, when you said 'Never had a problem with these media before', were they tried on this same Panasonic player that you mentioned?
My Panasonic set-top (A110) was listed as "doesn't play DVD-Rs" (when I last checked, that is), but I discovered that it'll accept TDK DVD-Rs (2x) only (so far, I've only tried TDK and an el-cheapo brand). With that, maybe you can get a diff brand of media (start with 1 disc only so it won't hurt that much if it doesn't work also).
That's the only thing I can think of. Maybe other members have been in the same situation as you... -
ac3 avi movies don't play back in 5.1 on divx dvd player
By funkyspaceman in forum AudioReplies: 10Last Post: 22nd Oct 2015, 16:01 -
Problems with play back packard bell dvd player
By muay in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2010, 12:08 -
DVD Play Back
By rcoran in forum Portable VideoReplies: 1Last Post: 4th Oct 2009, 02:26 -
Player that can play back m2v and ac3 files in sync
By cheerful in forum Software PlayingReplies: 2Last Post: 9th Sep 2009, 20:48 -
dvd play back problems
By cbbs02 in forum Authoring (DVD)Replies: 4Last Post: 13th Jun 2007, 18:43
