Are there any suggestions of what software to use to capture with scene detection from a dv-cam (firewire connection), withouth beeing forced to edit in the same software? Those that I´ve tested (bundled with card) either results in avi files that seems corrupted when trying to edit in premiere (half the resolution), or doesn´t have the option of saving the captured scenes as avi files (has to be edited at once).
Thanks in advance...
Thread: Capturing with scene detection?
Ulead DVD workshop will capture with scene detection. It captures each scene to a seperate AVI file.
Craig Tucker,
I saw your response about the scene detection capture using Workshop and I tried it last night - it seemed to work ok but when I import the AVIs in to Premiere the properties are shown as 360 x 288. It does not seem to create a 'normal' DV AVI as in Explorer, right-click, properties, advanced - does not show the DV codec , or bitrate as I normally get with Pinnacle or Premiere captured DV AVIs. In MedaStudio, however, the analyse tool does show it as 720 x 576 ?
Do you have an ideas? -
This is exactly what I found out using wincoder/producer (I think it was..) that came bundled with some hardware. But yesterday I bought Scenalyzer after beeing really fed up with Pinnacle express etc, and I have to say that it was well worth the money ($33). I also have a computer with Pinnacle DV500+ with Pinnacle DVtools bundled, but this software does not even come close in competition with Scenalyzer when it comes to speed and stability. I can only agree with one of the user comments on Scenalyzer´s website: "How can a programmer think so different? It can only be, that you are a DV user and did not find a suitable DV capture. So you wrote it yourself. And the result is great - It would have saved me so much time which I can use with my son, who is the main actor in my movies." So, I wonder then: have anyone found any drawback with Scenalyzer? Except that you did not bought it earlier...
Scene Detection and Cutter for MPEG File
By klode in forum EditingReplies: 6Last Post: 6th Nov 2011, 19:39 -
Capturing DV tape to one file, or multiple files by scene?
By Obtong in forum EditingReplies: 4Last Post: 12th Jul 2011, 13:03 -
Scenalyzer, optical scene detection
By BTB554 in forum Capturing and VCRReplies: 2Last Post: 16th Jun 2011, 00:48 -
MPEG2 Encode - Scene Change Detection (Apple Compressor vs Adobe vs other)
By rallymax in forum EditingReplies: 7Last Post: 21st Jan 2011, 20:44 -
Scene change detection
By Lele in forum Newbie / General discussionsReplies: 2Last Post: 9th Oct 2008, 03:13
