I am looking for the best quality entry level capture card, i also want to export to external video projector via my video card.
the best display reolution of the Win Tv is 1600x1200 but has only a capture res' of 384x288/avi according to this sites comparison table.
on the other hand the ATI Radeon has a max display res of 640x480 but can capture up to the same resolution in avi also with mpeg at 352x288.
From the site i have read that it is possible to force cards up to a capter resolution of 640x480 is thi possible of the Win TV.
I run Win ME With 512ram on 1.2 Ghz Epox.
Thanx to anyone who replies.
Marko.
Hi
I just had a look and can select max 768 X 568 capture size, however if I try to capture at that size in uncompressed AVI I would loose more frames than I would capture.
P3 450, http://www.hauppauge.com/ Win TV, maybe you might do better. I can capture using DivX at a larger size, but mostly use 340 X 288 DivX and it will not loose any frames.
Haup 500 PCI + WMM; good vids, no audio. Help?
By cwb in forum Capturing and VCRReplies: 8Last Post: 5th Sep 2010, 22:00 -
ATI HDTV Wonder PCI
By NautTboy in forum Capturing and VCRReplies: 3Last Post: 16th Mar 2010, 01:00 -
I can't get my ATI tv wonder PCI 650 to capture
By Onceler2 in forum Capturing and VCRReplies: 5Last Post: 28th Nov 2009, 10:47 -
Capturing TV Broadcasting using ATI TV WONDER 650 PCI
By jluke in forum Capturing and VCRReplies: 3Last Post: 6th Nov 2009, 01:10 -
I have questions about this ati all-in-wonder pci-e card
By yoda313 in forum ComputerReplies: 0Last Post: 6th Sep 2008, 10:23
