How many of you have used VOBrator and had it quit or hang on you?
It's a GREAT program but the problems almost made it not worth the effort.
This evening I took the time to try different COMPATIBILITY settings in XP. Most of us have our video set at a minimum of 800 or 1024 with 16 bit color. I run my system at 1600 with 32 bit color.
VOBrator wants 256 colors! So if you are using XP right click on the VOBrator icon and go to PROPERTIES and COMPATITILITY and select RUN in 256 COLORS.
This solves 99% of the problems. I have still seen the message "Failed to render graph" occur in VOBrator but I believe this is because of the information in one VOB ID that I tried to access. Also it did hang after accessing a very big VOB ID.
If you are unable to get any and pictures to display when using VOBrator it's probably the lack of a video codec.
You can find VOBrator version .2b here:
http://www.digital-digest.com/dvd/downloads/encoding_vobutils.html
My GUIDE DVDXCOPY improvements - or how to remove .VOB ID's shows several examples of using VOBrator:
http://www.vcdhelp.com/forum/viewtopic.php?t=127933
Results 1 to 1 of 1
Lg-bd630 stutter problem solved!
By RogerTango in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Feb 2012, 14:18 -
Avidemux Crash Problem
By rock99 in forum SubtitleReplies: 7Last Post: 5th Feb 2010, 07:09 -
altDVB Problem crash !
By designbuyers in forum DVB / IPTVReplies: 1Last Post: 7th Mar 2009, 20:55 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 00:38 -
Problem ripping CRASH
By vice86 in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2007, 09:27
