  1. I have an avi file i want to convert to mpg and then there is an srt file. The only problem is that i can't load the avi in either virtualdub nor tmpgenc, though it does play with the subtitles in WMP, any help?
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    did you follow any one of the guides to the left first ?
  3. Yes of course, or else I wouldn't be here right?
    Anyways, yeah I just simply can't load my avi file when I want to convert it. In virtualdub, it says it cannot determine the file type.
    Mar 2002
    Manchester, UK
    It could be a missing codec on your machine (e.g. xvid).
    Use AVICodec (You can find it under Tools to determine what codec the AVI is using.)
    If Avicodec shows a "Green Tick" next to the avi, then you do have the correct codecs, so please ignore me
    <edit> Sorry, you can't get it from tools here (I'm sure that's where i got it from though). Try http://avicodec.duby.info instead
  5. Thanks for the tool Grumpy! It seems that the file is okay, it has the video and audio codecs. Is it possible that there is some imcompatability issues with TMPGenc and virtualdub? I still cannot load the file in either of the programs. I download a tool called GSPOT and it identified the video and audio codecs that the avi file is using. For the video it says that the codec is not installed! The strange thing is that the codec it uses says DivX 5.0 and this 4cc code named DX50. Some help would be greatly appeciated! Thanks in advance!
