I have some SVCD files that I have been trying to convert to VCD format.
I looked around and DVD2AVI frameserving seems to be the easiest way to do this. I did this with one file and it worked just fine and dandy frameserving to TMPG. Now when I try to open up the .mpa file created by DVD2AVI, TMPG hangs and locks up. I tried wiping out and re-installing both TMPG and DVD2AVI....but the problem still occurs.
I then tried changing the DVD2AVI audio processing to "decode to wav", but it will not produce an audio file when I do this, just makes the .d2v file.
What I need is either another way to convert my SVCD to VCD (without taking up massive amounts of HD, IE converting to raw avi)....or some way to produce a wav file from the svcd rather than the .mpa that DVD2AVI produces.
Oh yeah, I tried using winamp because it is fairly good at opening just about any MPEG audio file, and it will not open the .mpa file created by DVD2AVI (this is not a fluke, I have tried creating several mpa files from various svcds and none of them open).
Any help would be greatly appreciated.
--hectma
try de-muxing with tmpgenc, which will leave you with an .mp2 file.
then download dbpoweramp from www.dbpoweramp.com and use this to convert your MP2 to WAV.
-MarkSwim with me
And we'll escape
All the trouble
Of the present age
Finally free -
once you've gotten the mp2 file, then you can encode the video only to VCD specs, and then mux w/the mp2 file--unless, of course, your SVCD audio is something other than 224, in which case, you'll need to reencode the audio to 224 and then mux w/the new videoOriginally Posted by geek rockwhat are you askin' me for...
I'm an idiot!
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 07:25 -
no audio after conversion?
By bviruet in forum ffmpegX general discussionReplies: 1Last Post: 15th Apr 2008, 02:25 -
No Audio after conversion
By gcam in forum Video ConversionReplies: 6Last Post: 19th Feb 2008, 14:53 -
.ts conversion - no audio
By saintloup in forum ffmpegX general discussionReplies: 1Last Post: 14th Feb 2008, 17:27 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11
