I just want to verify a point before I make a decision. Is it normal for DVD players to not support MPEG2 sound? So if someone is using Ulead DVD or DVDit! or Spruceup and they use MPEG2 files then there DVD will have no sound on playback? I would like to use Ulead DVD workshop since it has so many nice menus and buttons and it's so fast, but the DVD's I make with it only play back on my Apex but no sound on my Pioneer. How do people use Ulead and then author DVD's that they know will play if they give them away as gifts? I'm at a loss on this one
Results 1 to 25 of 25
yes -- this is common , many players in N. America do not support mpeg audio on dvd's ..
That's odd how software companies do that (also equally odd is how DVD players wouldn't support it). I guess b.c AC3 encoders aren't cheap.
Does your Pioneer play SVCD or VCDs? -
i find this problem rare. ive sold over 200 dvd-rs and this has happened twice. but in both instances it would play in a different player (computer) most people or rarther alot of people can play the mpeg-2 audio.
Although it is true that there are desktops players that won't recognize mpeg2 audio, most do!
My Pioneer will play VCD, SVCD, XVCD, but not DVD authored with MPEG2. Are you guys saying most standalone DVD players will play them? If not, how do people use Ulead DVD workshop? It only authors to MPEG2 and nothing else, it doesn't give the option to convert audio to pcm, at least not that i can find
Originally Posted by BJ_M
CommanderXJL
Which model Pioneer would not play the mpeg 1 layer 2 audio? Was the audio 48KHz?
The NTSC DVD spec at the left states mpeg 1 layer 2 audio is supported but one track has to be ac3 or lpcm. I don't believe stand-alone DVD players are intended to enforce the DVD specs and would not play the DVD mpeg 1 layer 2 track if the ac3 or LPCM track was not present. If the DVD player can play VCDs or SVCDs it can play mpeg 1 layer 2 audio. I would like to know if using mpeg 1 layer 2 is a real problem. It was reported on another thread that a stand-alone DVD player would not play DVDEdit Pro ac3. Nothing is easy.
If you want to make a NTSC DVD that meets spec with DVDWS you could mpeg encode your video with TMPGEnc... with mpeg 1 layer 2 audio. Import the video and create your menus with background music... On finish select Make disk using LPCM audio but check do not convert video files. You will have a video with mpeg 1 layer 2 audio and menus with LPCM audio. Does that meet the DVD spec of one LPCM track and one mpeg 1 layer 2 track?
BTW The ac3 license can't be too costly when the $50 editing/authoring software at http://www.mediostream.com/ supports ac3.[/b] -
The newest 1.3 patch available for Ulead Workshop does now offer the the addition of LPCM audio.
Originally Posted by Feuerwehr
all dvd players have to support ac3 audio .. that 59$ neodvd program is 2ch ac3 .. though a pretty good bargin (dont know about the rest of it) ..
some models of dvd that dont play all mpeg audio -> pioneer 343, 434 7200, 7400 , panasonic combo LD/dvd player , Delphi car player (dont know model) ... -
Don't know my model right off hand, but it's a 5 disk changer. I am encoding my captured AVI's with TMPG with the DVD template audio is 48khz
Originally Posted by CommanderXJL
I would recommend you use BeSweet to transcode your wave to ac3 using the procedure outlined http://vcdhelp.com/forum/viewtopic.php?t=129419&highlight= but some people have reported problems. Personally I have had no problems using BeSweet. I suspect that some of the problems may be caused by the user not selecting the correct audio sampling rate (48KHz). Still an unknown. -
As it stands I will most likely continue to use BeSweet until Ulead releases MSPro 7 in March. -
when I convert to ac3 with besweet or soft encode then author in any program the picture freezes in my pioneer but not my Apex. This player has no problem with vcd, xvcd, svcd, but god I'm going crazy trying to just use mpeg2 files or converted ac3 files. I may just have to use spruceup or maestro and go with PCM files. Nice how Ulead won't let you update the trial of workshop to 1.3
However, it is not mandatory for NTSC players to do so -- it is OPTIONAL. If you want maximum NTSC compatibility, then encode your audio in Dolby-Digital (AC-3) which is REQUIRED to be supported. -
well I'm an idiot, the reason my Pioneer wasn't playing the mpeg2 sound was I needed to go into the setup menu and tell it too. For some reason on vcd or svcd it does it by default, but on DVD you have to go in and set it up
Let this be a lesson to anyone else, check your setup menu if you have sound trouble
many players support mp2 audio, but only when it is accompanied by AC3 or PCM.
Originally Posted by Greg12
I seem to be having the same problem. I capture home movies using the PVR-250 card, which only allows me to capture audio in mpeg 1 layer 2 format. If I author the dvd using Unlead movie factory, my set top player (Toshiba SD4700) only plays video without sound. If I take the same capture and author with Sonic MyDvd (which converts audio to PCM), it plays just fine.
The downside to using MyDvd is that the audio eats up so much room on the DVD. Anyone know of any way around it? Can I convert audio from my captured mpeg to ac3 and re-multiplex it / author it with Unlead? how?
thanks. -
Originally Posted by AsimL8
To answer your last question you can transcode mpeg 1 layer 2 to AC3 but that is very lossy. You can mux ac3 and video with TMPGEnc but Ulead DVD Movie Factory does not support AC3. Lastly, the question of the of BeSweet's ac3 file structure compatibility remains open. -
Dvd-players with usb-resumable-playback support?
By sonam in forum DVD & Blu-ray PlayersReplies: 9Last Post: 12th Nov 2010, 12:54 -
Portable DVD Players With USB Support
By JohnDodds in forum DVD & Blu-ray PlayersReplies: 4Last Post: 10th Jan 2010, 16:17 -
what DVD players support most video formats?
By BassJunkie in forum DVD & Blu-ray PlayersReplies: 11Last Post: 14th Feb 2009, 11:54 -
dvd players that support rmvb??
By lilxtwinkies in forum DVD & Blu-ray PlayersReplies: 4Last Post: 25th Sep 2007, 23:03 -
DVD Players that support WMV videos...
By Tap_Artist in forum DVD & Blu-ray PlayersReplies: 4Last Post: 13th Jul 2007, 13:56
