This forum is the best.
Thanks for all help you guys have give me.
I should burn an mini dvd on cd-r media.
and wnat to split the .m2v file in pieces.
apreciate for help.
Where does the M2V file come from? Your encoder?
Use the "source range" abilities of your encoder to encode in smaller chunks. The downside to that is you'll have to perfectly edit your AC3 file to match or you'll loose sync (dont ask me how to do it, I dunno!).
Your DVD rip?
Rip by chapter, or just in smaller chunks that equal roughly 650mb. The upside is you'll keep your AC3 file matching your video exactly. The downside is .. well, there is none I can think of ... This is how I do it, actually. -
ok.
I have use tmpgenc.
and yes I have the ac3 sound.
ok I should try to rip by chapter....
m2ts to m2v
By pcb in forum Video ConversionReplies: 6Last Post: 20th May 2010, 21:22 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
muxing m2v with m2v?
By just in forum Newbie / General discussionsReplies: 4Last Post: 30th Dec 2008, 00:05 -
PAL in m2v?
By gameroftheuk in forum Newbie / General discussionsReplies: 3Last Post: 7th Aug 2008, 22:38 -
M2V Video Help
By beforethedawn in forum MacReplies: 19Last Post: 23rd Sep 2007, 20:46
