Hi
I have posted this problem 2 times before, but now i did a Format c:, i got new codecs, new burn programs and new films.
My problem : when i download a movie i encode it and burn it as a vcd pal movie to play on my DVD. When i play it, it's mirror like and UPSIDE down. If i see it on the computer before encoding and burning it's fine no problems !!!
I tried NERO - virtualdub - TMPGEnc -vcdeasy -winoncd.
I HAVE NO IDEA WHAT TO DO NOW ????
I have burned before without any problems !
Please help me !!!
Koerth
i dont know what your problem is, but i think i know how you can flip
the movie so you will encode it and have a good mpeg.
1. open the avi with virtualdub
2. press "video" and then press "filters"
3. press "add"
4. select "flip vertically"
5. press "ok"
6. press "ok" again
7. press "file"
8. press "start frame server"
9. press "start"
10. choose a file name for it
11. press "save"
if you need to flip it to the left or the right, try "flip horizontally"
now you can use tmpeg to convert the avi.
(use the file that virtualdub created)
hope it helps...HELL AINT A BAD PLACE TO BE -
OK
I will try that, but what do i do abouth the mirror thing, it is like looking into a mirror ??? -
Lots of people with the movie upside down syndrome fixed it by installing the nimo codec pack. It is not a 100% guaranteed solution, but it's worth a try. Good luck
Expert advice needed regarding mpeg2 (ts) to mpeg4 (h264) encoding issue
By janvandenberg in forum Video Streaming DownloadingReplies: 16Last Post: 13th Dec 2011, 17:52 -
Need expert help : Video re-encoding
By cyberlion in forum EditingReplies: 10Last Post: 6th Jul 2010, 14:16 -
FLV expert help
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 11th Aug 2009, 05:08 -
Need Major help from an expert!
By jbartosh in forum MediaReplies: 38Last Post: 23rd Oct 2007, 12:45 -
Is this possible? MPC expert please
By ferry1 in forum Software PlayingReplies: 3Last Post: 8th Jun 2007, 18:09
