I have a Philips DVDR990 and have made several DVD+R(W)s from own tapes. I am considering buying a DVD+RW (SONY or NEC) for my PC to edit video.
I have a few questions about how the PC drives are used:
1) Is it possible to make an exact bit-for bit copy of my own DVD+RWs? If yes, can this be done in multiple "generations" - copy of copy of copy...?
2) Can I pick titles/chapters from own DVDs and copy them to DVD+R(W)s in a simple way, or do I need to edit/copy/convert several files?
3) Do I need extra software beyond what is usually included with the drives to do these operations?
4) Should I have an extra DVD reader in the PC, or do I have to copy via hard drive anyway?
- Thanks
1 - yes
2 - well i think its simple to do .. though you need to re-author
3 - have no idea what software comes with that drives but most likely - maybe , for 1 above , no , for 2 above , perhaps
4 - either way works fine and same result the end ..
?!! Exact Audio Copy vs. dBpoweramp !!?
By flashandpan007 in forum AudioReplies: 12Last Post: 1st Jun 2011, 15:21 -
Exact Copy of DVD made in Poland from Hard Drive of LG recorder
By dubronidog in forum MacReplies: 5Last Post: 18th Nov 2010, 09:14 -
exact copy with more than 2 folders ?
By takenotes in forum MacReplies: 3Last Post: 27th Oct 2010, 20:19 -
Exact copy of a DVD to a container playable in itunes
By jamsponge in forum DVD RippingReplies: 5Last Post: 20th Jan 2009, 10:19 -
how do i copy DVD RAM discs to pc hard drive (retaining exact file quality)
By mnbvc in forum Authoring (DVD)Replies: 3Last Post: 19th Apr 2008, 17:32
