I have an old vhs camcorder made by panasonic. I am wanting to capture my vhs tapes to my pc and burn them to a disk that I can watch in my DVD player.
1. I bought Pinnacle Linx USB capture card and Pinncale studio 8.
2. I captured image at the best possible analog resolution without any frame drops. This resolution was 320x240.
3. Next I converted movie to MPEG 1 for quality and compression size.
4. I burn the movie as a VCD and play it in my DVD player.
5. It works!!
6. It looks like crap.
7. I know, garbage in, garbage out.
8. What can I do to see this movie on my DVD player as clear as I would through my VCR?
Please help, I plan to buy a mini-dv, but that doesn't help me with the 10 tapes I already have.
Steve
Check this out, read through a bit for the juicy bits.
http://www.vcdhelp.com/forum/viewtopic.php?t=127563
Also, try searching "VHS" in forums for other posts. Most info can be found via a search."speed's just a question of money. How fast can you go?" - Mad Max, 1979 -
Originally Posted by s_konstanty
Thanks,
I'm totally new to this so bear with me. I have read a number of posts related to VHS, but am still not "getting it".
I capture the analog vhs tape at 320x240(or whatever the best quality capture is in studio 8, the frame rate is 29.9 fps, and the bit rate is fixed...something like 4Mbs)
I convert that to mpeg1 and burn it as a vcd. I can view it in my dvd, but it looks very lossy or as I call it, CRAP on the screen.
What I NEED to know. Is there other software out there that is going to allow me to capture at higher bit rates and resolutions so that I can burn it as a VCD, SVCD, or DVD and watch it in my DVD player having the ORIGINAL quality that I get from watching through my VHS. AND what setting would I use. I didn't find any of this information in the FAQ for newbies.
Somebody please help me!!! -
You must capture better than 320x240. USB cap devices get slammed pretty regularly here (the 1.0 ones anyway). You may want to try a cheap tv tuner card (like mine). I capture at 352x480 when I make VCDs and while they aren't "DVD" quality, the are very watchable.
Capturing VHS to PC with a high definition resolution...?
By dark_myuutwo in forum Capturing and VCRReplies: 108Last Post: 10th Jun 2016, 11:18 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 22:16 -
VHS to DV capture: Component video vs. S-VHS
By vega12 in forum Capturing and VCRReplies: 8Last Post: 19th Feb 2009, 19:42 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31
