My Avermedia VCR app can capture at either 640x480 or 720x480. I can also pick whatever bitrate I want. If I am going to making SVCD's, do I need to chose a high bitrate when I capture? When I go to TMPEGec to convert, it will only let me choose 2500 for the bitrate. Does that make a difference?
Also, what resolution should I choose to capture in, 720x480 or 640x480?
TIA
TMPG WILL let you use a bitrate other than 2520kbs. You have to select "load" and find "unlock.mcf" Beware if you do that, you will be making a non-standard SVCD (or an XSVCD). I wouldn't bother capping above 640x480 if you are making a SVCD (which ends up 480x480).Originally Posted by kgeissler
What bitrate should I use on my orignal cap from Avermedia VCR? Should I just use 2520, or go higher?
Definately go higher.....
The higher quality the source the better the encode will be.
Try anywhere between 6000-8000 bitrate.
Fozzee -
I would also suggest using the highest resolution available, provided you can capture w/out dropping frames.
what are you askin' me for...
I'm an idiot!
Bitrate Question
By x0pht in forum Video ConversionReplies: 5Last Post: 18th Jan 2011, 00:00 -
Bitrate question
By SuxRight in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2010, 01:45 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 16:01 -
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Bitrate question
By eclipse95 in forum Video ConversionReplies: 7Last Post: 10th Nov 2009, 23:03
