I followed the directions here. When I click on "Save WAV..." it won't let me save it and gives me an error. I can save the WAV without the steps on the site but its horrible quality.
Please help![/url]
I have trouble with virtualdub and audio sometimes too. I would try to save the wav file with TMPG and see if it is the wav file or vdub crapping out......Originally Posted by enferno
here is what the error says:
The requested audio compressio is not compatible with the input format. Check that the sampling rate and channel count of the input match those of the requested format. -
I used to get that too.
I'm not sure exactly what cured it, but it was fixed after I
- Reinstalled Windows XP
Installed Codecs
Installed latest version of Virtualdub (v1.4.13)
Hopefully (for you), it's the last one that actually fixed it
You have to keep the same sampling/bitrate. Otherwise you have to convert(seperate process). This shows up a lot with 48Khz/96Khz sources.
I have Ver. 1.4.10. I'll try to upgrade.
Garzorgan, please explain what that means. I'm not up to the media lingo.
Problems re-using VirtualDub
By djdust in forum Newbie / General discussionsReplies: 17Last Post: 27th Apr 2011, 09:57 -
.mkv problems in Virtualdub
By alc112 in forum Video ConversionReplies: 14Last Post: 11th Feb 2010, 00:47 -
virtualdub dv type 2 problems
By sander815 in forum Video ConversionReplies: 26Last Post: 21st Nov 2009, 20:58 -
Problems with Virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 4Last Post: 8th Jun 2007, 10:23 -
A couple of VirtualDub problems.
By Rein Engel in forum Capturing and VCRReplies: 5Last Post: 1st Jun 2007, 04:07
