Just bought me a new cdrw writer "LITE-ON LTR-52246S Rev: 6S07 " and now i can't burn with vcdeasy!!!! And with Nero i got sync problems so is there any other good software that support overburn when you making SVCD's?
Bytheway here is my error log in EasyVCD.
[CDRDAO Write]
WARNING: During writing you should avoid to open the Windows Explorer and similar tools
WARNING: CDRDAO does not lock the recording device so that all access action from the Explorer will lead to a failure of the recording process.
Cdrdao version 1.1.7
1,1,0: LITE-ON LTR-52246S Rev: 6S07
Using driver: Generic SCSI-3/MMC (raw writing) - Version 2.0 (options 0x0000)
ERROR: Try again first, then
WARNING: Length of toc (83:08:21, 374121 blocks) exceeds capacity of CD-R (79:57:74, 359849 blocks).
WARNING: Ignored because of option '--overburn'.
WARNING: Some drives may fail to record this toc.
Starting write simulation at speed 2...
Turning BURN-Proof on
Using 16 byte P-Q sub-channel data mode.
Writing lead-in and gap...
Writing track 01 (mode MODE2_RAW/AUDIO )...
Writing track 02 (mode MODE2_RAW/AUDIO )...
cmd finished after 3.410s timeout 20s
ERROR: Write data failed.
ERROR: Writing failed - buffer under run?
ERROR: Simulation failed.
