im a bit confused about what happens when you resize a movie
if i have a divx which is 640 x 272 & i encode it to (for istance) cvd which i beleive is resolution D1 352 X 576 (PAL) does this mean i loose resolution on the width & stretch the vertical resolution?
i am very confused about how resizing works & would appreciate some help here![]()
Yes and no.
640x272 is most likely not interlaced. What FPS? if it's DVD, it 'should' be 24 fps. If it's 30 fps, someone didn't know what they were doing.
Are you PAL? if not don't encode to it. 352x576 @ 25 fps is really 352x288 at 60 fields/second ( 2 fields to a frame for interlaced ).
Summary, you won't lose much with the conversion. Pay attention to the frame rates. That will make a bigger mess than the resolution. converting 24 fps to 25 isn't too bad. -
thanks for the speedy response
im converting an NTSC divx to PAL CVD as im British
i dont really have a problem with framerate etc im just trying to find out what happens in the resize process -
Hi I live in Sweden and have a couple DivX movies which is fps is 23.976.
Can I just burn it and play it on my DVD or do I have to encode something,if so how? -
If the source is NTSC, leave it as NTSC. If you are in the UK your hardware will almost certainly play it with no problems. Converting to PAL can be a pain and can cause playback problems such as video stutter.Originally Posted by boboyo
Youtube HD Resolutions
By bseos in forum Video Streaming DownloadingReplies: 12Last Post: 14th Oct 2011, 11:50 -
Screen Resolutions
By ranosb in forum Video ConversionReplies: 4Last Post: 25th Aug 2009, 03:04 -
Capture resolutions?
By visionman in forum Capturing and VCRReplies: 6Last Post: 28th Jan 2009, 13:13 -
Question about resolutions
By ShinKyo in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 09:44 -
Really confused about resolutions....
By sam9s in forum DVB / IPTVReplies: 6Last Post: 12th May 2007, 13:42
