  1. When i extract a wav in doirect stream mode in Virtual dub,rename to *.ac3 and try to convert to wav with Azid,it says canīt find synch all the time,and the end file is only 44 kb large,i hae tried everything,what can i do? I need a wav i can use in TMPGenc to convert an avi.
  2. Member Treebeard's Avatar
    Aug 2002
    you need to use full stream mode
  3. Canīt do that,then virtualdub says unknown stream format, that is why i use the direct stream copy,so i can rename the direct stream wav to *.ac3 then convert the file with Azid,then i get a workable wav. I CANNOT use the drirect stream wav,as every program i try say unknown format,and i have all codecs installed.
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    you sure it was a ac3 file to start with ?
  5. No, but whenever i have an avi i canīt "full process" with virtualdub i use direct stream and it always works..I know the file is encoded in divx 5.02,and i have that codec..
