I got a couple of AVI files which seem to be encoded using Divx5 and I can't get the audio to play.
I know it must be missing codec. I'm using MS Media Player 9 under WinXP and when I load the files, it tries to download a missing codec but fails to do so.
At first, I didn't have the video either, so I downloaded Divx5 bundle and installed it. Now I get the video, but no audio.
I installed ACE Mega CodecS Pack. It partially solved the problem: I had audio, but the video was shaky, even MPEGs or older AVI movie files which used to play perfectly. So I was now able to get the the audio, but the video output was awful. I know I have a pretty slow computer, but why files the used to play well were now all shaky?
So I uninstalled ACE Mega CodecS Pack and tried Nimo Pack instead. The same shakiness occured.
Installing the AC3 codec doesn't solve the problem either.
Here are data provided by codec identifying softwares for 2 files I have problem with:
GSPOT --------------------------------------------------------------------------
For File1:
VIDEO FORMAT CODEC
4CC: DX50/DIVX
Codec is installed
Details: Gspot has found Divx decoder filter, which is installed on your system, is a 'primary' match, and based on that, the video for this file should play fine.
Nonetheless, DirectShow is apparently NOT able to play this file (see "DirectShow Render", below). No further informatio is available concerning the apparent discrepancy
AUDIO FORMAT CODEC
Name: adpcm (0x0002) Microsoft Corporation
Codec not installed
Details:
Format tag: 0x0002
Format tag name: WAVE_FORMAT_ADPCM
Format vendor: Microsoft Corporation
Gspot was not able to find an audio codec which will decompress this format. DirectShow was not able to render it either. You will most likely need to get an audio codec update to get sound from this media clip.
For File2:
VIDEO FORMAT CODEC
Same info as above.
AUDIO FORMAT CODEC
Name: alaw (0x0006) Microsoft Corporation
Codec not installed
Details:
Format tag: 0x0006
Format tag name: WAVE_FORMAT_ALAW
AVIcodec -----------------------------------------------------------------------
File 1:
File : 9 Mb (9 Mb), duration 0:00:49, type AVI, 1 audio stream(s), quality 78 %
Video : 8 Mb, 1435 Kbps, 29.970 fps, res. 320*240 (4:3), DX50 = OpenDivx V5, unsupported
Audio : 1 Mb, 178 Kbps, 22050 Hz, 2 chan., 0x2 = MS ADPCM, unsupported
File 2:
File : 8 Mb (8 Mb), duration 0:01:29, type AVI, 1 audio stream(s), quality 30 %
Video : 7 Mb, 740 Kbps, 25.0 fps, res. 320*240 (4:3), DX50 = OpenDivx V5, unsupported
Audio : 0 Mb, 64 Kbps, 8000 Hz, 1 chan., 0x6 = CCITT A-law, unsupported
I understand that I'm missing the MS ADPCM codec but if I click on the link provided by AVIcodec, I get to Microsoft's website, which has very little info on the subject. It seem the MS ADPCM codec is supposed to be provided with VFW. To my understanding, I should have it installed by default.
I've searched using Google to find info about how to install the ADPCM codec but all I could find was conserning Win9x. Nothing can be found for WinXP. Even Microsoft's Knoledge Base has nothing about ADPCM for WinXP.
Could anyone advise me on this?
Results 1 to 1 of 1
Virtualdub and audio codec missing.
By nzdreamer55 in forum EditingReplies: 20Last Post: 29th Dec 2013, 23:32 -
missing mp3 audio codec in ulead when saving as avi
By gabz in forum Video ConversionReplies: 3Last Post: 24th Jul 2011, 16:23 -
Needed : A adpcm audio codec link plssssss x
By xJensbigproblemx in forum AudioReplies: 3Last Post: 30th Jun 2010, 00:41 -
Western Digital HD TV Media Centre - Missing audio codec support
By Hcw87 in forum Media Center PC / MediaCentersReplies: 5Last Post: 21st Jul 2009, 13:55 -
IMA ADPCM codec on vista
By TigerShark in forum AudioReplies: 0Last Post: 12th Dec 2007, 22:00
